Best approach for velocity profile in compressible flow
Old   January 31, 2019, 14:10
Default Best approach for velocity profile in compressible flow
Alex
AlezXander is on a distinguished road
I am simulating the flow in a channel with the density based solver in Fluent. I understand that a velocity inlet boundary condition is not recommended for this case, it is better to use for example a pressure inlet (Fluent warns you if you check the case with a velocity inlet).
However I want to use a specific velocity profile using a UDF. Should I just compile the velocity profile and use it on the velocity inlet BC or is there a more suitable way of doing this?
Thank you for your time.
AlezXander is offline   Reply With Quote
Old   February 1, 2019, 11:04
Lucky
The issue is that, for compressible flows, there is a supersonic and subsonic solution that will both satisfy this velocity profile. If you are 100% sure you are trying to constrain a velocity profile, then use a velocity inlet BC.
Old   February 4, 2019, 12:08
Alex
I understand, thank you for your answer.
velocity profile in a simple cylindrical flow tube Diger FLUENT 0 December 29, 2016 22:05
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
compressible flow maria teresa FLUENT 1 September 7, 2007 17:58
urgent help needed with 2d compressible flow James FLUENT 2 June 20, 2007 05:22
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 18:23
