Reverse flow due to zero inflow velocity
Old   February 6, 2019, 12:20
Default Reverse flow due to zero inflow velocity
feroz
ferozheloise is on a distinguished road
I performed the pipe flow analysis (using FLUENT) which has velocity pulsation as an inflow condition. The pulsation image is attached here. In case 1, pulse initiates and terminates at zero velocity. On the other hand, in case 2, pulse initiates and terminates at 0.5 m/s.
I successfully completed the analysis for case 2 without any problem. However, in case 1, there is a problem of reverse flow at the pipe pressure-outlet, and this retains throughout the steady and transient analysis.
Upon investigation, I found out that if there is a zero inflow velocity, there occurs reverse flow always, which I verified by performing the analysis where I used constant zero velocity at the inlet boundary condition. Moreover, unlike case 2, during hybrid initialization, case 1 showed zero values in all the iterations.
Can anyone please provide his/her experience and solution to avoid reverse flow in such situations?
Many Thanks
Last edited by ferozheloise; February 6, 2019 at 12:30. Reason: Uploaded image again
ferozheloise is offline   Reply With Quote
fluent - udf, pipe flow, reverse flow
Trackbacks are On
Reverse flow at Outlet ARUN K RAJ Main CFD Forum 4 March 18, 2015 10:43
Problem with time average tangential velocity in swirl flow. lakhi FLUENT 5 July 18, 2012 17:28
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 13:14
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
