Sliding Mesh- Creating Periodic Zones Problem |
February 17, 2019, 13:05 |
Mehmet
Rep Power: 7 |
Hi friends,
I have a project about 2D translational rotor-stator periodic analysis on ANSYS Fluent. I have set the interfaces without problem. When I tried to set periodicity to stator bottom-top edges and rotor bottom-top edges, I have wrote the codes in the console, but the periodicity failed with the message "number of elements are not equal between the zones" as follows: /mesh/modify-zones/make-periodic Periodic zone [()] 9 Shadow zone [()] 10 Rotational periodic? (if no, translational) [yes] no Create periodic zones? [yes] yes Auto detect translation vector? [yes] yes Error: Failed to make zones periodic. Error Object: #f Warning: Number of elements does not match between zone 9 and 10. I have changed the default matching tolerance from 0.05 to 0.5 using the code " /mesh/modify-zones/mathing-tolerance ", but it hasn't worked unfortunately. I will be very glad to have helps from you about my problem. You could see the 2D geometry and fluent fail messages in the attached files. My Best Regards |
February 18, 2019, 05:07 |
Rep Power: 10 |
Like I wrote in the other thread, check your flow axis in Cell Zone Conditions
February 18, 2019, 16:20 |
#3 | |
Mehmet
Rep Power: 7 |
Thanks for your feedback. If you have further solutions, I will be very thankful for you. |
February 18, 2019, 17:25 |
Lucky
Rep Power: 65 |
Don't use auto-detect but manually input the translation vector.
You need a conformal mesh on the periodic pair (means the mesh must be exactly the same). It says you have wrong number of faces so leads me to think you don't have a conformal mesh. You can change tolerance all you want, but if there are different number of faces, then it's obvious.... |
February 19, 2019, 15:33 |
#5 | |
Mehmet
Rep Power: 7 |
February 21, 2019, 07:24 |
PRAVEEN KUMAR
Rep Power: 8 |
Have you matched the mesh for those two edges?
Use match control option during meshing. |
February 21, 2019, 15:35 |
Mehmet
Rep Power: 7 |
February 21, 2019, 15:41 |
#8 | |
PRAVEEN KUMAR
Rep Power: 8 |
So, it will match without having higher tolerance value! |
#9 | |
Mehmet
Rep Power: 7 |
February 21, 2019, 15:46 |
#10 |
Mehmet
Rep Power: 7 |
February 21, 2019, 15:51 |
#11 |
PRAVEEN KUMAR
Rep Power: 8 |
February 22, 2019, 14:00 |
#12 | |
Mehmet
Rep Power: 7 |
What's wrong with it? https://www.sharcnet.ca/Software/Ans...Face_Mesh.html |
February 28, 2019, 13:22 |
#13 | |
Mehmet
Rep Power: 7 |
I have solved my problem and overcame the periodicity problem. It was caused due to the creating names for the edges in meshing. I had created the periodic names for the all length of the edges which was incorrect as seen in the photo "incorrect name selection". I have changed the name selections making blade profiles as wall, you can see in the photo " correct name selection". Aften then, I was able to see the velocity vectors in the results. Thanks your helps I just demand some literature articles about 2D or 3D turbomachinary axial water or air flow analysis using Fluent. If you have some articles about it, it will be very helpful for me to decide blade chord length, inlet velocity/pressure, turbulent viscosity values selected on Fluent. best regards |
Sliding / Dynamic Mesh in heat transfer problem | platzhalter | FLUENT | 0 | May 7, 2018 05:25 |
[ANSYS Meshing] Solution to periodic boundary problem | SophieLee | ANSYS Meshing & Geometry | 1 | June 28, 2017 01:51 |
Sliding mesh problem - no flow through interface | pawel26 | FLUENT | 0 | May 14, 2017 12:25 |
Periodic sliding mesh | Tarin | FLUENT | 0 | February 28, 2014 09:18 |
[GAMBIT] Problem in link face mesh for periodic | newbie384 | ANSYS Meshing & Geometry | 1 | June 28, 2013 06:31 |
