UDS value go infinitie!
Dear all,
i have a problem in using UDS! i have a pipe and i want to solve a scalar! in 2D simulation I have no problem! But in 3D geometry I have problem! I solve the flow at first, then turn off the flow equation and solve only for UDS! My mesh is very low at first layer! (It is because of adjacency of pipe with another pipe which is in scale of Micrometer!) the geometry in a simple one-eight of a cylinder with symmetry B.C at sides! the problem comes when I change the B.C of scalar! at first i use "specified value" at inlet and wall of pipe and "specified value" at outlet! so far everything is ok! but when I change the scalar B.C of outlet to "Specified flux of 0" at outlet, even at first iteration my solution diverges! values become negative and very large! is that come from mesh or something else??? if i didn't explain well, please tell me to tell more details! Thanks in advance. |
Why you are putting specified flux of 0 at an outlet?
You're saying, that in 2D, you also did specified flux of 0 at the outlet and it did not blow up? :mad: |
in 2D simulation i set that and all of my answers where correct! can u help me please??? and one more strange thing is that when i use a coarser mesh in 3D simulation there isnt any problem :| |
Could you solve the problem with minus infinity? I have the same problem when I use bigger cells.
