AAS Matlab toolbox - Journal file
I have succesfully connected both Fluent and Matlab through the toolbox. The following command succesfully prints the summary on the matlab console.
iFluentTuiInterpreter.doMenuCommandToString('report summary') Code:
iFluentTuiInterpreter.doMenuCommandToString('file/read-journal "Journal.jou"') |
iFluentTuiInterpreter.doMenuCommandToString('file read-journal \"Journal.jou\" ') |
Thanks for your fast reply but I still get the same error.
long time ago I've read somewhere that you can't run journal in aaS regime (but i'm not sure about it 100%)
so you may write your journal in matlab and run as regular TUI commands best regards |
Okay, yes i'm doing it one by one. Do you happen to know any place where I could find useful examples of TUI commands?
I manage to do most of thing but I'm trying to set the value of the velocity-inlet of 4 boundaries to a udf profile but I don't manage to write the correct syntax. It has to be something similar to: Code:
iFluentTuiInterpreter.doMenuCommandToString('define/boundary-conditions/set/velocity-inlet (pv4 pv3 pv2 pv1) vmag yes yes pvs_profile') |
iFluentTuiInterpreter.doMenuCommandToString('define/boundary-conditions/set/velocity-inlet pv4 pv3 pv2 pv1 () vmag yes yes pvs_profile') in console press enter, you will see the list of TUI commands. I dont know about any file with description of TUI commands best regards |
Thanks for your responses!!
Kind regards |
