AAS Matlab toolbox - Journal file
Like Tree3Likes
  • 1 Post By AlexanderZ
Old   March 12, 2019, 06:16
Post AAS Matlab toolbox - Journal file
Mikel
Xabierenko is on a distinguished road
I have succesfully connected both Fluent and Matlab through the toolbox. The following command succesfully prints the summary on the matlab console.
iFluentTuiInterpreter.doMenuCommandToString('report summary')
Nevertheless, when I try to load the journal file I find the followin error.
iFluentTuiInterpreter.doMenuCommandToString('file/read-journal "Journal.jou"')
AAS_CORBA.EFluentGenericError: IDL:AAS_CORBA/EFluentGenericError:1.0
	at AAS_CORBA.EFluentGenericErrorHelper.read(EFluentGenericErrorHelper.java:80)
	at
    AAS_CORBA._ICoFluentSchemeControllerStub.doMenuCommandToString(_ICoFluentSchemeControllerStub.java:126)
I have tried changing in several ways the input file but I don't manage to solve this problem.
Xabierenko is offline   Reply With Quote
Old   March 12, 2019, 20:53
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
iFluentTuiInterpreter.doMenuCommandToString('file read-journal \"Journal.jou\" ')
best regards
Xabierenko likes this.
AlexanderZ is offline   Reply With Quote
Old   March 13, 2019, 04:17
Mikel
Thanks for your fast reply but I still get the same error.
Old   March 13, 2019, 20:36
Alexander
long time ago I've read somewhere that you can't run journal in aaS regime (but i'm not sure about it 100%)
so you may write your journal in matlab and run as regular TUI commands
best regards
Old   March 14, 2019, 11:42
Mikel
Okay, yes i'm doing it one by one. Do you happen to know any place where I could find useful examples of TUI commands?
I manage to do most of thing but I'm trying to set the value of the velocity-inlet of 4 boundaries to a udf profile but I don't manage to write the correct syntax. It has to be something similar to:
iFluentTuiInterpreter.doMenuCommandToString('define/boundary-conditions/set/velocity-inlet (pv4 pv3 pv2 pv1) vmag yes yes pvs_profile')
Old   March 14, 2019, 20:37
Alexander
iFluentTuiInterpreter.doMenuCommandToString('define/boundary-conditions/set/velocity-inlet pv4 pv3 pv2 pv1 () vmag yes yes pvs_profile')
you dont need to put names of boundaries into brackets
in console press enter, you will see the list of TUI commands.
I dont know about any file with description of TUI commands
best regards
Old   March 15, 2019, 02:50
Mikel
Thanks for your responses!!
Kind regards
aas, fluent, matlab
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
