March 28, 2019, 17:52 |
[Error] SIGSERV when continuing simulation
#1 | |
Luiz Oliveira
Rep Power: 7 |
I am currently trying to use an tracer to find the residence time within a certain region of my domain. To do so I run an unsteady simulation to stabilise the flow and then I patch the tracer and run with multiphase turned on and data sampling turned on. Since my domain requires a periodic condition I have to keep deleting my tracer on inlet by an automatic command, and hope that the flow is sufficiently stabilised since I lose capabilities of controlling the flow by mass due to multiphase. The problem is that once I read the case of the second simulation and the data from the first, I can't continue calculation due to the error: Quote:
So far I've tried running on serial, turning off my automatic commands and redistributing partitions without success. I can manage to run both simulations individually but not together. Also if there is a better way on finding Residence Time Distribution I am accepting suggestions. Thanks! |
parallel, read data, sigsegv, tracer |
Help running SST k-omega Stress-Blended Eddy Simulation | DA6righthand | FLUENT | 0 | July 15, 2017 10:44 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 06:48 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
