Why doesn't my simulation solve two energy equation? |
April 8, 2019, 08:32 |
Rep Power: 8 |
Guys,
I'm trying to simulate heat transfer in a conical body which is under cooling using a helical channel that water is throughing in it. here is two screenshoot of the body: The point is that Fluent doesn't solve two energy equation(energy equation for our fluid and solid). In fact it solve one energy equation and it doesn't converge properly. Here is a screenshot of the residuals: Here is a screenshot of the equations in Fluent Methinks that Fluent cannot recognize the existens of the solid body although the two body are avalible in Fluent, see Questions:
April 8, 2019, 09:05 |
Moritz Kuhn
You are sure that your solid domain is well connected to your fluid domain, that meas a heat flow is possible?
April 8, 2019, 09:17 |
#3 | |
Rep Power: 8 |
No, I'm not sure. How can I check it? Forgot to say that this is first time that I'm doing a heat-transfer project between a solid and a fluid. |
April 8, 2019, 09:31 |
Lucky
Rep Power: 65 |
Can't see pictures but...
There is only one energy equation. Make sure you have proper connecting boundaries (interfaces!) between your fluid and solids. |
April 8, 2019, 09:32 |
Moritz Kuhn
For two-sided internal walls, the coupled boundary treatment between solid and fluid is always applied to wall and wall-shadow pairs. So under your boundary condtions you have to have something named with "shadow". If not, you can achive it under the thermal setup up of the face between your bodies and choose "coupled"
April 8, 2019, 21:33 |
Alexander
Rep Power: 34 |
I recommend you to delete contact surfaces in design modeler and remesh your model, so you will get conformal mesh.
Looks like your problem comes from bad mesh best regards |
April 9, 2019, 16:24 |
Andrea
Rep Power: 8 |
Just plot heat flux and se if is 0 at the interface. If the mesh is not connected the flux will be 0
April 9, 2019, 17:07 |
Lucky
Rep Power: 65 |
I can see the pictures now! But we are being bamboozled!
Equations doesn't show energy equation at all! But your residuals plot clearly shows an energy residual. Stop trolling. |
April 11, 2019, 06:41 |
#9 | |||||
Rep Power: 8 |
Sorry guys for delay and thank you for your replies
But we have to different body, a solid and a fluidic body and due to this file: http://www.afs.enea.it/fluent/Public.../PDF/chp11.pdf We have two energy equation. Please pages 2 and 6 One for fluid and one for solid So Fluent should solve two energy equation. Isn't it correct? Quote:
Can you see the image? I don't know if these notations could be related to my problem. Quote:
Do you see any problem? Quote:
http://uupload.ir/filelink/rUzQUlkjtx89/k3c_geom.zip Quote:
No joking, no bamboozling, no kidding,... I have enough problem to attend. No time for kidding. Quote:
The Case & Data files are around 15MB. Would you like to see it? I can upload them somewhere to get it. |
April 11, 2019, 13:00 |
#10 | ||
Lucky
Rep Power: 65 |
I'll just tell you even though you don't believe me that once you get Fluent set up properly and everything is working, you will find only one energy residual. There are lots of different forms of the energy equation and different ways to write it down, but there is only one principle of energy conservation. If you look closely you'll notice the energy equation in a solid is just a special case of the energy equation of a fluid.
The point of someone telling you to check the heat flux is to check that the heat flux is not zero. So you have a non-zero heat transfer coefficient? Then there is heat transfer from solid to fluid and everything is working. |
April 11, 2019, 13:53 |
#11 |
Rep Power: 8 |
Yeah it looks but not properly.
April 11, 2019, 22:23 |
#12 |
Alexander
Rep Power: 34 |
in my opinion the problem is your mesh (poor quality and interfaces)
best regards |
April 18, 2019, 11:33 |
#13 | |
Rep Power: 8 |
How can I make sure that the problem is because of mesh quality or interfaces? For example when I do a "mesh check" for this project, I get this report: Code:
Domain Extents: x-coordinate: min (m) = -1.375240e+01, max (m) = -1.369300e+01 y-coordinate: min (m) = -1.648760e-02, max (m) = 1.649027e-02 z-coordinate: min (m) = -1.648960e-02, max (m) = 1.648955e-02 Volume statistics: minimum volume (m3): 4.396650e-14 maximum volume (m3): 2.868624e-10 total volume (m3): 1.178235e-05 Face area statistics: minimum face area (m2): 3.506865e-10 maximum face area (m2): 9.237542e-07 Checking mesh............................ Warning: Found 6 left-handed faces on sliding interface zone 6. Mesh interface check failed! Done. WARNING: Mesh check failed. To get more detailed information about the mesh check failure increase the mesh check verbosity via the TUI command /mesh/check-verbosity. It says that mesh interface check has failed. What could it mean? Why is it a warning? Why it's not an error? How could I figure out this failure? I've tried to use all of the commands in the sub-branch of "/mesh/repair-improve" to repair or improve the mesh but no progress has gained, so far! Any other idea? Edit: Here is some links to the similar problem: Mesh check failed https://studentcommunity.ansys.com/t...-check-failed/ |
buoyantPimpleFoam General Assumptions (thermophysical model, energy equation, etc) | AMK53 | OpenFOAM Running, Solving & CFD | 1 | October 23, 2018 05:30 |
Energy balance in conjugative/ porous simulation; Domain Energy is greater than Input | Vishnu_bharathi | CFX | 2 | June 27, 2018 10:08 |
Questions about the energy equation | aestas | Fluent UDF and Scheme Programming | 5 | April 6, 2014 11:28 |
Source term energy equation for reactive flows | DaIN | Main CFD Forum | 0 | October 6, 2011 15:11 |
Need help:about energy equation in CFX | Stein | CFX | 4 | July 2, 2009 22:31 |
