Execute commands through the AAS Toolbox
Hi! So I have been trying to add the execution of a couple of commands from Matlab making use of the AAS Toolbox. I basically copied the structure that you input in the TUI command prompt on fluent but when I put it in Matlab it doesn't work.
These are the couple of commands that need to be executed which when introduced on the TUI command prompt work perfectly: Code:
solve/execute-commands/add-edit a 41 "time-step" "define/boundary-conditions/zone-type wall) 7 pressure-outlet" Code:
iFluentTuiInterpreter.doMenuCommandToString(['solve/execute-commands/add-edit a 41 "time-step" "define/boundary-conditions/zone-type wall) ',num2str(mv),' pressure-outlet"']) |
wall) change " to space"space best regards |
Thanks for the fast answer! I don't know if I fully understand what do you mean by change " to space"space. Do you mean the following?
iFluentTuiInterpreter.doMenuCommandToString('solve/execute-commands/add-edit b 41 " time-step " " define/boundary-conditions/pressure-outlet mv yes no 1067 no yes yes no no no "') |
