About rmse velocity and rms velocity
Like Tree8Likes
  • 1 Post By starz
  • 7 Post By LuckyTran
Old   April 9, 2019, 06:02
Post About rmse velocity and rms velocity
none
starz is on a distinguished road
In the Fluent, we can plot the contour of RMSE velocity magnitude (not only velocity but also for other parameters) base on the sampled LES results. However, as I checked, RMSE and RMS are two different concepts.
RMSE is short for root mean square error, which is defined as:http://statweb.stanford.edu/~susan/c...it/node60.html
It is the root mean square of the instantaneous velocity subtract by the average velocity.
RMS is not an error. It is the root mean square of the instantaneous velocity without subtracting anything.
I checked the ANSYS Fluent Theory Guide. I only find RMS in instead of RMSE. And in our Forum, people are mostly talked about RMS.
Therefore, I am confused. Is RMSE in Fluent is the root mean square error of velocity or root mean square of velocity?
Thanks
Best regards
StarZ
soheil_r7 likes this.
starz is offline   Reply With Quote
Old   April 9, 2019, 17:14
Lucky
This question has been asked over and over and over again.
As you state correctly, RMS is root mean square of instantaneous velocity without subtracting anything. RMSE is the root mean square error, which is equivalent to the RMS of the fluctuating velocity.
For unsteady flows, it was presumed obvious that we are looking for RMS of fluctuating velocities. But then one day people realized that RMS of velocity is confusing. So Fluent changed the labeling from RMS to RMSE to make it clearer that it is calculating RMSE. Fluent has always calculated RMSE, but you will find it labeled RMS in the program or manual.
For turbulent flows people are talking about the RMS of the fluctuating velocity (rms of u', v', or w'), which is the RMSE of the instantaneous velocity. A lot of people say RMS when they actually mean RMSE. Heck a lot of people call u',v', w' as "the rms velocity."
soheil_r7, roi247, starz and 4 others like this.
definition, rms velocity, rmse, unsteady flow
RMS Velocity values Firefly STAR-CCM+ 0 April 26, 2016 13:29
Prob in rms velocity components, pls help.. sakurabogoda CFX 5 February 13, 2013 21:30
Can RMS velocity even be smaller than mean velocity? lgas222 FLUENT 4 May 23, 2012 04:36
RMS velocity in Cylindrical coordinates ? lcw FLUENT 2 October 5, 2006 04:49
RMS velocity coordinates transform ??? lcw FLUENT 0 February 22, 2006 22:29
