maximum mole fraction and pre-defined inlet methane mole fraction
Old   May 10, 2019, 21:09
Default maximum mole fraction and pre-defined inlet methane mole fraction
Weiqiang Liu
Weiqiang Liu is on a distinguished road
I am modelling methane catalytic combustion in micro-channel including both gas phase and surface mechanism. My current work is to reproduce literature results. However, the maximum temperature is always 200 k lower than literature results. I put the computed temperature contour below.
All residuals are below 1e-6 and keeps flat. I can not figure out why this happen. I checked the contour of methane mole fraction and found the calculated maximum methane mole fraction is 0.09. However, the inlet pre-defined methane mole fraction is 0.105. I believe these two values should be the same. I also guess this is the reason why my simulation temperature is 200K lower than literature results.
I am wondering how can I solve this problem. Is it because the case still not converged or something wrong with my model.
Please help.
Weiqiang.
Weiqiang Liu is offline   Reply With Quote
inlet, maximum temperature, mole fraction
