Help. I cannot get the correct value of input parameters by using RP_Input_Parameter
Hello everyone.
I wanna know how to access the correct value of parameters in workbench. I creat a parameter named "Volume Flow" and registered it. After press "Print"., the information shows as follows; Input parameters available in udf side .................................................. ............................................... parameter-name current-value id-to-be-used-in-udf .................................................. ................................................ "Volume Flow" 1.23 real-1 .................................................. .............................................. I think this information shows that I creat the parameter successfully and the value of this parameter is 1.23 Then I tried to use a UDF to print the value on the screen to make sure that I can access the parameter. The UDF code is: DEFINE_INIT(initial,d) { real a; a=RP_Input_parameter("real-1"); printf("a= %f\n,a); } The result is always "a=-0.000000" no mater how did I adjust the value of "real-1" So have I missed something important? How can Iget the correct value of this parameter. please help. Thanks and regards. |
