Writing journal and script file.
Hello friends,
I am trying to run Fluent simulation on my university's HPC. As far as I know, I need 4 files to do that.
Here is what my script file looks like: script #!/bin/bash # #PBS -N example #PBS -P RDS-FEI-niroCFDThesis19-RW #PBS -l select=1:ncpus=2:mem=1GB #PBS -l walltime=00:05:00 # Load the Ansys module module load ansys/192 cd $PBS_O_WORKDIR # Start fluent using the specified journal file fluent 3ddp -g -mpi=intel -pinfiniband -cnf=$PBS_NODEFILE -t$nprocs -i tut7.jou Here is my journal file: tut7.jou file read-case FFF.2-Setup-Output.cas solve initialize hyb-initialization solve iterate 200 report system time-stats file write-data FFF.2-13-00188.dat exit This is my cas file: FFF.2-Setup-Output.cas This is my dat file: FFF.2-13-00188.dat I tried submitting the job to the HPC. What happens is that the HPC load the fluent module and after 2 minutes the computation fails. Am I doing the right thing? |
read log file in working directory
best regards |
As far as I know, I have kept the script, journal, cas and dat files in the same directory. |
check working folder on claster, log file should be created after you get an error
best regards |
Show us what happens. What is the terminal output or the log file for the HPC? There are inumerable reasons why it might fail. |
