May 29, 2019, 04:55 |
CFD analysis of low reeynolds number airfoil
bakar
Rep Power: 13 |
hi, i am simulating low reynolds number flow over E387 airfoil. For meshing i am using ICEM.
Firstly i perform a grid study (reynolds number 200,000, alpha 4), increasing the mesh size and checking pressure distribution , lift and drag coefficient. Final grid (also attached fig 1 and 2 ) give wall y plus less than 1 (convergence 10e-4). Pressure distribution lift and drag coefficient very close to experimental. To capture laminar separation bubble i am using SST transition model, intermittency =1 , tub intensity = 0.1% (from wind tunnel data) and Tub ratio = 10 (as default). SIMPLE coupling, 2nd order spatial discretization. pressure distribution plot, fig 3. Then I ran alpha sweep on the final grid. I am having problems at alpha 8 and higher. Fluent is unable to resolve the flow. (fig 4 and fig 5) In literature, very good results have been presented using same scheme and transition model. Can some one guide me and let me know what i am doing wrong. I am not an expert in CFD, i am sorry if i miss some details .. fig 1.bmp fig 2.bmp fig 3.bmp fig 4.bmp fig 5.bmp |
May 30, 2019, 00:11 |
Alexander
Rep Power: 34 |
what is Alpha -> angle of attack?
start with last converged solution (let it be solution for aoa=5) change aoa little bit (for aoa=6) and continue computation (don't initialize) continue this iterations best regards |
May 30, 2019, 01:01 |
bakar
Rep Power: 13 |
yes . alpha is angle of attack ..
i will try it .. thanks for you comments |
May 30, 2019, 01:36 |
bakar
Rep Power: 13 |
i have tried it .. did work ...
results are the same.. no improvement ... |
May 30, 2019, 06:52 |
Alexander
Rep Power: 34 |
you may try to use transient simulation with small timesteps.
Imagine a particle flow through your domain with input velocity, so that particle should went through your domain twice, for example: your domain is 20m, velocity is 100m/s, so you have to simulate at least 0.4 sec physical time. With timestep = 0.001 -> it will be 400 time step. Also check Cd and Cl best regards |
August 30, 2019, 04:10 |
Fabio Malizia
Rep Power: 15 |
Try to change P-V coupling (ex. Coupled). Might help.
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
