arash
Rep Power: 17 ![]() |
I simulate direct injection engine with heptane fuel. Abnormally during injection I see this message :
umber tracked = 54497, escaped = 0, aborted = 0, trapped = 0, evaporated = 1266, incomplete = 0, incomplete_parallel = 0, coalesced = 2692, shed = 1370, splashed = 1492 Deleted 21 particles in injection injection-3 with total mass 5.238089e-15 kg Deleted 8 particles in injection injection-2 with total mass 2.620605e-15 kg Deleted 1 particles in injection injection-3 with total mass 2.598588e-16 kg iter continuity x-velocity y-velocity z-velocity energy k epsilon c8h18 o2 time/iter 5125 2.8582e-03 1.0445e-05 9.9964e-06 2.3042e-05 8.3657e-08 3.4721e-04 1.9184e-06 9.3095e-04 3.8301e-07 0:04:11 60 Error at Node 14: Invalid cp (0.000000e+00 J/kgK) for n-octane-air at temperature 1.#QNAN0 K Error at Node 15: Invalid cp (0.000000e+00 J/kgK) for n-octane-air at temperature 1.#QNAN0 K Error at Node 0: Invalid cp (0.000000e+00 J/kgK) for n-octane-air at temperature 1.#QNAN0 K Error at Node 1: Invalid cp (0.000000e+00 J/kgK) for oxygen at temperature 1.#QNAN0 K Error at Node 2: Invalid cp (0.000000e+00 J/kgK) for n-octane-air at temperature 1.#QNAN0 K Error at Node 13: Invalid cp (0.000000e+00 J/kgK) for n-octane-air at temperature 1.#QNAN0 K MPI Application rank 0 exited before MPI_Finalize() with status 2 ************************************************** ************************** * hwloc has encountered what looks like an error from the operating system. * * Socket (cpuset 0xfff000ff) intersects with Socket (cpuset 0x000fffff) without inclusion! * Error occurred in topology.c line 940 * * Please report this error message to the hwloc user's mailing list, * along with any relevant topology information from your platform. ************************************************** ************************** The fl process could not be started. I realy don't know what happend? |
muhamed elbadawi
Rep Power: 10 ![]() |
i have faced the same error, did you solve it ?
Alexander
Rep Power: 35 ![]() ![]() |
from log we may see, the problem is related to temperature.
Check your model setup
best regards ****************************** press LIKE if this message was helpful |
Rajesh
Rep Power: 0 ![]() |
I am using air-hydrogen mixture for combustion in Mach 2. I used K-e and species transport model with 10 species and 21 reaction in fluent. I am getting invalid Cp after 5000 iteration if I am using mixing law for Cp and after 4000 iteration if chemkin law. Please help me to troubleshoot this problem. The picture is attached.
Display Modes | |
Error: Invalid cp (0.0000 J/kg K) detected (Species and dpm model used in fluent) | hive.cfd | FLUENT | 4 | September 12, 2022 03:47 |
postProcess -func sampleDict does not create output folder | tmr2044 | OpenFOAM Post-Processing | 7 | April 27, 2021 14:33 |
Simple supported beam, incorrect solution | optymista93 | Structural Mechanics | 0 | November 15, 2017 10:36 |
Getting incorrect u-velocity profile by solution | Dharma Vedula | Main CFD Forum | 3 | September 12, 2017 02:35 |
[DesignModeler] Naca 0012 Error at Dimensions | F1 Master | ANSYS Meshing & Geometry | 3 | May 28, 2017 18:56 |
