Duplicating/pattern results for same geometry but multiple separate instances |
June 17, 2019, 11:41 |
Sandesh
Rep Power: 9 |
Hi All,
I am using FLUENT to simulate temperature distribution inside water-cooled copper coils/tubes. The original/assembly has 7 IDENTICAL coils (attached) that are equally spaced out in 360 deg i.e I have 7 coils that don't touch each other but and have the same heat load and water flow conditions. I have made a simulation in fluent studying the temp distribution in ONLY one of the coil. Can I somehow copy/pattern/duplicate the results to apply on the remaining 6 coils. I have read about using cyclic pattern but they seem to apply where the bodies are connected i.e like a wheel. The goal here is to export this data to steady state thermal and link it with other bodies and then move to structural simulation to study thermal expansion/stress .....and on and on. I have done this part for a single coil (please see attached). So, I guess the results don't necessarily have to be duplicated in fluent itself, maybe I can duplicate them in steady state thermal? Appreciate the help! |
fluent, post procesing |
Forces results on multiple elements | Santos-Dumont | FLUENT | 3 | January 23, 2013 09:31 |
Interpolating a results file onto multiple identical domains | jtipton2 | CFX | 0 | June 7, 2011 11:44 |
[ICEM] Simple Geometry Poor Results | tav98f | ANSYS Meshing & Geometry | 4 | August 4, 2010 13:36 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
Results from multiple processors | Radhika | Siemens | 2 | February 11, 2007 23:44 |
