Additional walls appear in FLUENT BC for multibody part. |
June 23, 2016, 05:09 |
Euan
Rep Power: 9 |
I have used ANSYS Meshing and created a multibody body part as I want a conformal mesh.
The multibody part has resulted in extra walls appearing for the boundary conditions in FLUENT. The default settings for these are no-slip walls. I am not sure exactly where these walls are so I ran a simulation and tried to plot a contour on the walls however FLUENT came up with a message stating cannot plot on sliding interface. I have plotted velocity and pressure contours on the planes I created which ran down the centre of the fluid domain and nothing strange appears to be happening i.e. the fluid hitting a wall the interface of the parts of the multibody. If anyone can shed any light on this it would be much appreciated. |
December 27, 2016, 10:40 |
#2 | |
fahimeh
Rep Power: 9 |
Hi Euan, Did you get the answer??? I have exactly the same problem as yours. regards, Fahimeh |
December 27, 2016, 23:26 |
#3 | |
Kushal Puri
Rep Power: 12 |
July 26, 2019, 08:31 |
Hossein
This may help you.
https://studentcommunity.ansys.com/t...h-extra-walls/ |
conformal mesh, fluent, interface, multibody part, walls boundary conditions |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Coupled walls - Ansys Fluent 12.1 | Geisel | FLUENT | 2 | May 4, 2010 05:21 |
Exporting part names to Fluent | morourke | ANSYS Meshing & Geometry | 1 | February 22, 2010 11:36 |
Additional turbulence models for FLUENT | Travis | FLUENT | 0 | December 19, 2008 11:58 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
