May 21, 2016, 14:41 |
Modeling ejector using fluent
Moh'd Khasawneh
Rep Power: 9 |
Hi fluent's
i need you valuable help please I'm modeling a gas ejector and i'm really stuck and toughly struggling In fact I'm working on 2d-axisymmetry modeling for supersonic ejector using NIST real gas for R134a and i'm not getting any convergence especially for continuity and x-velocity variables. also i'm getting REFPROP_error (203) from function: tprho (density) [TPRHO error 203] vapor iteration has not converged i will highly appreciate you kind assistance regarding the issue Yours Moh'd |
May 26, 2016, 02:35 |
Luke
Rep Power: 13 |
hello! have you tried before going with gases using air ideal gas or easier like water if the model you've set up really work?
May 26, 2016, 11:28 |
Re-Luke
Moh'd Khasawneh
Rep Power: 9 |
Thanks Luke for your kind reply
Yes i tried using ideal gas as a working fluid and first order schemes intending to use the results to initialize the true real gas NIST model but the convergence progress is very slow where its almost indicates a constant values for the scaled residuals even after 17500 iterations I would highly appreciate if you passed to the attachment file where i captured a snapshot for the scaled residuals history Yours Moh'd |
May 26, 2016, 11:37 |
Luke
Rep Power: 13 |
Hi, attached my residuals. how many elements do you have?
May 26, 2016, 11:42 |
Moh'd Khasawneh
Rep Power: 9 |
This report is generated by FLUENT
Awaiting your kind comment Mesh Quality: Orthogonal Quality ranges from 0 to 1, where values close to 0 correspond to low quality. Minimum Orthogonal Quality = 5.81132e-01 Maximum Aspect Ratio = 3.66096e+00 Domain Extents: x-coordinate: min (m) = -7.430342e-02, max (m) = 1.618900e-01 y-coordinate: min (m) = 0.000000e+00, max (m) = 1.311797e-02 Volume statistics: minimum volume (m3): 2.703190e-12 maximum volume (m3): 1.009905e-09 total volume (m3): 2.606182e-05 minimum 2d volume (m3): 1.216947e-09 maximum 2d volume (m3): 1.396445e-08 Face area statistics: minimum face area (m2): 2.710528e-05 maximum face area (m2): 1.405167e-04 Checking mesh........................... |
May 27, 2016, 02:20 |
Luke
Rep Power: 13 |
HI! It seem good! but i don't read the number of elements and i don't know your geometry but the quality is good. Have you tried non ideal gas?I mean air with constat density?if it doesn't work in this way probably there are some problems with the boundary conditions...I suggest pressure inlet and outlet and then compute the flow rate from the results
July 31, 2019, 03:34 |
#7 | |
ali
2d axisymmetric, ejector, flow, fluent, r134a |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
high continuity Fluent modeling ABL with WRF/CALMET data | xitao21 | FLUENT | 1 | May 2, 2019 10:20 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Modeling porous media with FLUENT | newcomer | FLUENT | 4 | September 26, 2013 00:08 |
Multiphase flow modeling: CFX or FLUENT? | Paul | Main CFD Forum | 8 | January 24, 2012 09:25 |
