Using the TUI to write/read profiles to update BC's? |
August 21, 2019, 10:18 |
Sebi
Rep Power: 7 |
For a cylinder of fluid with 2 phase flow, your inlet requires a VOF BC so lets put say 0.5 as an initial guess, which is applied uniformly to the inlet. In reality, this distribution may be different depending on their densities and visocisties. If you export the VOF at the outlet as a profile, and read it as the inlet VOF BC you now have a slightly better condition. If you repeat this several times you could generate a better approximation of the inlet VOF (Providing you have a cyclic velocity BC).
So far I am exporting the outlet VOF at the end of my solution using TUI, but then loading it as the inlet BC manually, and solving again using TUI and so on. Can I do this using the TUI entirely? Some example; PHP Code:
PHP Code:
Is this possible? |
August 21, 2019, 23:54 |
Alexander
Rep Power: 34 |
you code is here, why is it impossible?
run it In fluent GUI you can use calculation activities -> execute commands: read journal file each 800 time steps so you dont need to hardcopy each write/read iteration Check, may be periodic boundary condition is suitable for you best regards |
August 22, 2019, 07:51 |
Sebi
Rep Power: 7 |
rc profile.cas
/solve/initialize/hyb-initialization /solve/set/time-step 0.008 /solve/dti 100 30 /file/write-profile/ VOF-1 outlet () rbc-vof () /file/read-profile/ VOF-1 /define/boundary-conditions/velocity-inlet inlet rbc no no yes yes yes yes udf "CoronaryVelocityWaveform::libudf" yes no outlet rbc-vof /solve/dti 100 30 Is the code I ended up using or with a better explanantion: /define/boundary-conditions/velocity-inlet "name of inlet" "name of 2ndary phase" no no "yes normal to boundary" "Yes to setting up velocity udf at inlet" "name of UDF compiled" "yes to profile for multiphase" "no to UDF for multiphase" "origin of profile" "variable name" |
TUI commands for sample profiles in DPM | bloodflow | FLUENT | 4 | February 5, 2020 21:23 |
How to set BCs programmatically | incompressible | OpenFOAM Programming & Development | 6 | November 20, 2017 02:47 |
Change "Implicit Mesh Update Interval" using UDF | ASimonsen | Fluent UDF and Scheme Programming | 2 | October 12, 2017 09:38 |
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 11:58 |
Understanding Code behind BCs | Linse | OpenFOAM Programming & Development | 8 | January 9, 2012 08:58 |
