Writing Fluent Journal files Using TUI commands.
I am facing problems while writing the results using ANSYS Fluent TUI commands. Please go through the description section and attached images, please?
I was trying to extract result for wall_fuel_rod only like temperature velocity etc. However (please see the attached images), when I have entered the name of my desired surface ( wall_fuel_rod), it is demanding another surface which I do not want to add, so I pressed "Enter" button and it wants other parameters. I went through all the commands and found the result. But I need to make all the commands in a line like in a Fluent Journal file ( consisted of TUI commands ). Hence I tried but it shows error in surface (2) while I do not want to extract anything for another surface. In that case what should be my TUI commands or how can I fix the issue as I need to run the Fluent Journal file using MATLAB for Uncertainty Quantification. Thank you. |
To end a list you have to give the empty argument which is: ()
e.g. Code:
blah blah blah "wall_fuel_rod" () blah blah blah blah blah Also, there are no pictures... Funny, your problem didn't require any images to solve... |
