CFD analysis for leading edge airfoil
Old   September 7, 2019, 17:06
Default CFD analysis for leading edge airfoil
JYLEE is on a distinguished road
Hi, I am currently doing simulation on NACA 4412 airfoil but the lift obtained is ridiculously large (like 10^81). I have constructed lines for the structured mesh but the result is still the same.
My project is based on the following paper.
A parametric study on leading-edge slots used on wind turbine airfoils at
various angles of attack
Please give any advise or suggestion. Thanks in advance.
JYLEE is offline   Reply With Quote
Old   September 8, 2019, 02:26
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Attachment 72112
Attachment 72113
There are couple of issues. As this problem is very simple:
1. Units are not properly set. Or mesh is not scaled properly.
2. Reference values are not set correctly.
3. Mesh is not good enough
You can try ICEMCFD, it will give you much better control. You can also go for hybrid mesh. Mesh slot region with tetra elements.
Far is offline   Reply With Quote
Old   September 9, 2019, 07:59
Sir, thanks for the reply. I constructed the geometry with spaceclaim and i realize that I have too many Boundary Conditions.
What value should I put for the turbulence intensity and the length scale ? I am getting back flow at the outlet according to the console.
Here is my convergence plot for the parameters and the lift
[ATTACH]div-lift.JPG[/ATTACH]
Thanks in advance.
CFD analysis of low reeynolds number airfoil abu.bakar.ist FLUENT 5 August 30, 2019 04:10
airfoil edge via spline in OpenFOAM v6 jkampman Mesh Generation & Pre-Processing 0 November 26, 2018 05:19
Cfd to ansys thermal to ansys structural interface ssixr ANSYS 17 July 31, 2015 15:18
[ICEM] Importing cambered airfoil geometry to ICEM CFD kotimari ANSYS Meshing & Geometry 2 July 16, 2012 15:44
