September 12, 2019, 07:38 |
Mesh Independence Study Problems
Calum Hewlett
I am trying to run a mesh independence study on an under tray and diffuser for an FSAE car. I am measuring downforce along the diffuser edge as the parameter I am observing when refining the mesh. Specifically I am increasing the mesh density around the inlet and outlet of the under tray and diffuser I have tested 100000, 500000, 700000, and 1000000 elements. I have attached the screen capture from fluent post processing showing the velocity contour. It can be seen that as the mesh increases the output flow begins to form eddies. My downforce results are varying too much to conclude a reasonable mesh density to conduct further studies. Does anyone have any advice on how to resolve this problem, so that my downforce results to not fluctuate as much. Nothing is being changed inbetween the simulations other than mesh density. |
aerodynamics, ansys fluent, downforce, racecar, venturi |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
[Commercial meshers] Problems with ANSYS mesh conversion | tdog | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2016 17:36 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
