December 16, 2019, 10:29 |
Hydraulic Diameter for Axisymmetric Problem
samm
Rep Power: 7 |
Hello Everyone,
How can i calculate the turbulence inlet value (hydraulic diameter) for axisymmetric case. Normally diameter is considered as hydraulic diameter,here i can put one injector value as it is i.e, the diameter of that inlet. And how can i calculate hydraulic diameter for another inlet(which is along axis). Thanks. |
December 16, 2019, 11:19 |
Lucky
Rep Power: 65 |
Wait what? It doesn't matter if you simulate it using an axissymmetric approach. What's the whole injector thingy look like? Isn't it still a circle with a clearly defined diameter? Use that.
combustion, inlets, nonpremixed, turbulence |
diameter equivalent and hydraulic diameter | medaouarwalid | Main CFD Forum | 6 | June 22, 2017 02:33 |
Hydraulic diameter for multiple ducts | jalay | FLUENT | 2 | August 23, 2013 04:17 |
Hydraulic Diameter | vigii | FLUENT | 2 | January 14, 2012 10:29 |
equivalent diameter vs hydraulic diameter | swamysrikanth | Main CFD Forum | 1 | April 5, 2010 09:01 |
Hydraulic diameter vs radius | Christian | Main CFD Forum | 8 | August 5, 2009 18:10 |
