Problem setup and Boundary conditions for a heat exchanger using supercritical CO2 |
October 5, 2019, 17:41 |
Akshay
I have been trying to simulate flow through a unit cell of a shell and tube heat exchanger using supercritical CO2 as the working fluid for both the internal (tube) flow and external (shell) flow. I am having trouble obtaining a solution to the problem. I have used the NIST real gas database and I have tried simulating as an incompressible flow as well for simplicity but I cannot seem to converge my solution. I have uploaded a figure of my mesh and the details for my simulation are as follows: The black arrows in the figure depict external flow inlet and outlet. The red arrows depict internal flow. Maximum skewness of the mesh in 0.89. The mass flow rate throughout the cycle is constant as the heat exchanger is part of a closed loop. Turbulent flow: Assuming the k-omega SST model Pressure-based solver NIST real gas model for supercritical CO2 At tube inlet: Mass flow rate for each tube (Constant from inlet to outlet) : 0.00184 kg/s Pressure inlet : 250 bar Temperature at the inlet : 300 CelsiusAt the shell inlet: Mass flow rate (Constant from inlet to outlet) : 0.1032 kg/s Pressure inlet : 80 bar Temperature at the inlet : 800 CelsiusI have been at it for a while now, trying different possibilities but I feel like I am missing something basic. Could any of you be kind enough to help me out with obtaining the solution to this problem? |
compressible flow, heat exchanger, s-co2, supercritical flow |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
How to setup periodic boundary conditions in solid-solid heat transfer | liangLOL | FLUENT | 1 | July 20, 2018 03:58 |
CFX Spray Breakup Setup | Spray_Ansys | CFX | 28 | June 9, 2018 07:37 |
Euler unsteady with moving boundary conditions - problem setup | rocco.bom | SU2 | 0 | January 24, 2017 09:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
