Fluent Continuity establishment problem!
Old   October 12, 2019, 11:04
Cool Fluent Continuity establishment problem!
Mohammad Jam is on a distinguished road
1. I want to simulate a cylinder which has a velocity B.C at one side and it is closed at outlet(wall), so there is only 1 inlet and no outlet,
2. The solution of this problem must be diverged but fluent solves the problem with convergance!!!!!
3.The fluid is incompressible and is water and also inters the tube domain from inlet but would not exit!!
Thanks in advance.
Mohammad Jam is offline   Reply With Quote
Problem in compiling fluent UDF lunched from MATLAB cfdman10 Fluent UDF and Scheme Programming 16 December 5, 2019 05:32
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 06:08
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
