Aerodynamic lift and drag co-efficient for supersonic flow of atm re-entry vehicle |
November 7, 2019, 09:39 |
Ontario
Hey everyone, I need your suggestions regarding my simulation problem:
i am working on the 3D case of an atmosphere re-entry vehicle, the case is pure supersonic at Mach number 1.6 and angle of attack ranging from 140-170. Iam using density-based solver with an energy equation on. The problem is that for knowing the aerodynamic performance i am unable to get my desired results for my co-efficients of lift and drag. the major problem i am facing is either solution converges at just a few 1100 iterations or either it diverges.(showing temperature and then viscosity limitation) my boundary conditions include pressure far-field for complete grid and wall for my vehicle. if anyone can please help me out in this case to get the right answer. |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Estimation of viscous Lift & Drag coefficients from inviscid flow in optimization. | freebird | Main CFD Forum | 1 | June 3, 2018 03:40 |
Lift and drag force for 2D flow over cylinder model | Haonan Uwin | FLUENT | 0 | May 11, 2017 00:29 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Unsteady Flow past circular cylinder-Re=100 (fluctuating drag and lift co-efficients) | Vino | Main CFD Forum | 0 | April 10, 2014 09:39 |
