How to determine multicomponent diffusion using UDF |
January 12, 2020, 02:37 |
Tamil Nadu
Rep Power: 6 |
Hi all,
i include 5 species in my reaction and i want to determine the multicomponent diffusion through UDF. Dij was calculated as shown DEFINE_DIFFUSIVITY(diffusion_coef_crct,c,t,i) { Material *spi; Material *spj; int j; real mmass_i,mmass_j,ttemp,Pressure=1e+05,aux=0.0,aux1= 0.0,aux2=0.0,aux3=0.0,spe_name; ttemp=C_T(c,t); { mixture_species_loop(THREAD_MATERIAL(t),spi,i) { mixture_species_loop(THREAD_MATERIAL(t),spj,j) { if(i==0 && j==1) aux1 = collin_NplusN(ttemp); else if(i==0 && j==2) aux1 =collin_NplusN2plus(ttemp); else if(i==0 && j==3) aux1 =collin_NplusE(ttemp); else if(i==0 && j==4) aux1 =collin_NplusN2(ttemp); else if(i==1 && j==2) aux1 =collin_NN2plus(ttemp); else if(i==1 && j==3) aux1 =collin_Ne(ttemp); else if(i==1 && j==4) aux1 =collin_NN2(ttemp); else if(i==2 && j==3) aux1 =collin_N2plusE(ttemp); else if(i==2 && j==4) aux1 =collin_N2plusN2(ttemp); else if(i==3 && j==4) aux1 =collin_EN2(ttemp); else aux1= 1; } mmass_i=MATERIAL_PROP(spi,PROP_mwi); aux2=1E-03*(mmass_i/(6.022E+23)); aux =((KB*ttemp)/Pressure)*(3/8)*pow((((M_PI*KB*ttemp)*(aux2+aux3))/(2*(aux2*aux3))),0.5)*(1/(M_PI*1E-20*aux1)); C_UDMI(c,t,1)=aux; } return aux; } while iterating i get the error to be "mass diffusivity is Zero " please check the material property . please give me few suggestions to overcome the above issue. or whether i have to include UDS diffusivity for solving each diffusion of species. For example-N2,N2+,N,N+,e are the species considered and Dij - i= N2 and j=N then i want to calculated diffusion of N2 into N similary N2 into N2plus and so on. Kindly give me few suggestions to continue my work. Last edited by Sowmiya; January 12, 2020 at 23:30. |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 00:53 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Multicomponent fluid diffusion | houwy | OpenFOAM | 0 | April 14, 2014 08:37 |
mass diffusion vs temperature UDF | alex | FLUENT | 0 | March 5, 2008 11:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
