Why doesn't my two-step chemical model work?[For H2+air reaction][finite rate model]
Like Tree2Likes
  • 2 Post By Roh
Old   November 9, 2019, 13:28
Question Why doesn't my two-step chemical model work?[For H2+air reaction][finite rate model]
Roh
Roh is on a distinguished road
Guys,
I'm trying to use the two-step chemical model in my simulation. Here is the chemical mechanism:
Here is the reference of the mechanism:
https://www.researchgate.net/publica...-O2_combustion
I wrote this CHEMKIN file:
ELEMENTS
O  H  N
END
SPECIES
OH  H2  O2  H2O  N2
END
REACTIONS
H2+O2<=>2OH                     2.3E+22    0.000  10202
2OH+H2<=>2H2O                    1.83E+27    0.000  21992
END
I imported the CHEMKIN file and it's ok but the solution and the residuals doesn't look ok. See:
As you see the residuals of OH and H2O have oscilation. It should be noted that the solution is ok for one-step Hydrogen-air mechanism of Fluent.
What's the matter with this mechanism? What's your opinion? How to solve it?
Roh is offline   Reply With Quote
Old   December 1, 2019, 09:28
Roh
No idea??????
Old   December 2, 2019, 01:01
Tamil Nadu
Sowmiya is on a distinguished road
Hi Sir ,
I want to clarify how do you calculate activation energy value from the reference file you attached and the values you entered in chemkin file looks different???
Looks forward for the reply
Many Thanks
Sowmiya
Sowmiya is offline   Reply With Quote
Old   December 2, 2019, 02:24
samm
Jegan is on a distinguished road
Check your units ,that may vary.
Jegan is offline   Reply With Quote
Old   December 2, 2019, 08:30
Roh
Originally Posted by Sowmiya View Post
Hi Sir ,
Many Thanks
Sowmiya
Thank you Sowmiya and Jegan for reply,
Ok, let me tell you how I've written this CHEMKIN file. As it is said in this file (page No. 17):
https://www.et.byu.edu/~tom/classes/...dentmanual.pdf
The default units for A and activation energy are in terms of cm, sec, K, and moles. And also the Arrhenius equation is defined as(for CHEMKIN):
https://www.researchgate.net/profile...image/ar-1.png
As what is mentioned in the Article:
I attached a screenshot of the mechanism (table 1) that is mentioned in the article.
http://uupload.ir/files/2ru4_dyfuhjklkk.png
As you see in the screenshot, There are three parameters in the table; A, T, and n. I think that the authors of the paper didn't know that there are several forms of the Arrhenius equation.
I attached the screenshots of three forms. Here are the images:
https://www.researchgate.net/profile...image/ar-2.png
https://www.researchgate.net/profile...image/ar-3.png
Then I think the authors have made a mistake and the form of the Arrhenius equation for two-steps mechanism is this:
Thus, T should be Tar. The unit of this parameter is K but for CHEMKIN file we need to convert it to cal/mole (convert Tar to Ea). Ok, Therfore we multiply Tar by the gas constant which is 1.98720425864083 (cal⋅K−1⋅mol−1). For example for the first reaction mechanism we have:
5134*1.98720425864083=10202 cal/mole
For A, the units should be in terms of cm3, sec, and moles. Then we multiply A by 10e+6 to change the unit from m3.mol-1.s-1 to cm3.mol-1.s-1. Thus, e.g. we have:
2.3*10e+16*10e+6= 2.3*10e+22
This is the procedure that I've done to convert them.
Do you see any problem?
Jegan and Sowmiya like this.
Old   January 12, 2020, 01:40
Tamil Nadu
Dear Sir,
Thank you for clarifying my doubts clearly. Also I want to know when you convert Ea in chemkin file to cal⋅K−1⋅mol−1 but the fluent should have the unit of Ea in J/ kgmol. How you are correlating the units? Looking forward for the reply.
Many Thanks
Sowmiya
Old   January 12, 2020, 02:50
samm
Convert your cal/mol value into J/kmol
or in mechanism file we can write REACTIONS CAL/MOLE
This may work
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
Air entrainment model setup for spillway oajor FLOW-3D 4 November 17, 2016 12:02
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
error using combination of step function xujjun CFX 1 January 15, 2008 16:46
