November 10, 2019, 08:38 |
Solar collector boundary conditions
Bence
Rep Power: 6 |
I would like to make a simulation of a flat plate solar collector but I think my geometry is not working well. When I use interface to the contact regions after appr. 120 iterations the energy grows up. When I'm not using interface the result is always 5000K temperature the top of the absorber plate. I one mass flow inlet, one outlet and adiabatic wall expect the heat flux wall. I just draw the absorber plate and tubes that you can see on the following picture: https://ibb.co/bHy4Qk3 https://1drv.ms/u/s!AocT2y5AsSDSjjOK...PUoTD?e=9aAmMa Also share my last attempt. Can someone explain how to do it right? Thank you so much in advance, Ben |
November 10, 2019, 12:37 |
Rep Power: 9 |
If you have a certain heat flux, why dont you use only one pipe?
(Inlet massflowrate)/(pipe quantity) will be your massflow rate. The heat flux remain same value for the wall B.C. |
November 10, 2019, 13:56 |
Bence
Rep Power: 6 |
I would like to validate this geometry but I'm new to Fluent. So it's not an option for me to modify the number of tubes.
Display Modes | |
Export boundary setting in Fluent 14.0 | asal | FLUENT | 4 | September 28, 2017 10:40 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 18:19 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 02:54 |
