Solid domain in Fluid domain (meshing)
Old   November 10, 2019, 07:24
Default Solid domain in Fluid domain (meshing)
hyugakojiro999 is on a distinguished road
Hi to all,
Consider a pipe flow (D=10cm). And put something in it. May be a ball (D=5cm) in the middel of it without touching the pipe wall.
*Can we mesh these domains separately and combine them in FLUENT? So, there will be intersecting domains that FLUENT must consider the intersecting volume as the ball domain and leaving the fluid domain in that volume automaticly.
*I'm not asking the domain substracting method.
hyugakojiro999 is offline   Reply With Quote
Old   November 12, 2019, 12:13
Joshua
jbo214 is on a distinguished road
It sounds like what you are driving at is a mesh technique called overset (alternatively chimera) meshing. You create a grid for the background, and then a separate grid for various components that lie in the flow field, and the solver 'intersects' the two grids together to get a unified mesh built up from simpler meshes.
Check these resources out. It likely solves your problem.
http://2016.oversetgridsymposium.org...gger-ANSYS.pdf
https://www.ansys.com/-/media/ansys/...g-brochure.pdf
https://www.youtube.com/watch?v=jukm6w3vMXc
https://www.youtube.com/watch?v=_Cryhe7L3uw
jbo214 is offline   Reply With Quote
[ANSYS Meshing] Peoblem in meshing a tower in fluid domain a_gogoi@yahoo.com ANSYS Meshing & Geometry 0 September 6, 2017 03:04
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Fluid - Solid Domain Interface Daniel CFX 6 February 15, 2009 18:09
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
