November 10, 2019, 07:24 |
Solid domain in Fluid domain (meshing)
Rep Power: 9 |
Hi to all,
Consider a pipe flow (D=10cm). And put something in it. May be a ball (D=5cm) in the middel of it without touching the pipe wall. *Can we mesh these domains separately and combine them in FLUENT? So, there will be intersecting domains that FLUENT must consider the intersecting volume as the ball domain and leaving the fluid domain in that volume automaticly. *I'm not asking the domain substracting method. |
November 12, 2019, 12:13 |
Joshua
Rep Power: 11 |
It sounds like what you are driving at is a mesh technique called overset (alternatively chimera) meshing. You create a grid for the background, and then a separate grid for various components that lie in the flow field, and the solver 'intersects' the two grids together to get a unified mesh built up from simpler meshes.
Check these resources out. It likely solves your problem. http://2016.oversetgridsymposium.org...gger-ANSYS.pdf https://www.ansys.com/-/media/ansys/...g-brochure.pdf https://www.youtube.com/watch?v=jukm6w3vMXc https://www.youtube.com/watch?v=_Cryhe7L3uw |
[ANSYS Meshing] Peoblem in meshing a tower in fluid domain | a_gogoi@yahoo.com | ANSYS Meshing & Geometry | 0 | September 6, 2017 03:04 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Fluid - Solid Domain Interface | Daniel | CFX | 6 | February 15, 2009 18:09 |
