December 9, 2019, 20:23 |
Boundary Conditions for a Valve
Tom
Rep Power: 6 |
Hi All,
Iam working on a fire hydrant valve where I have to calculate 1.the outlet pressure( Max Limit is 4.5 bar) for a given Inlet pressure varying from 5 bar to 20 bar. In this case how I can give Boundary conditions? I have tried with Velocity Inlet and pressure outlet but I want to calculate for Varying Inlet pressure.? 2. Have to calculate the force actingin the piston( Top & Bottom). How CAn I calculate? I have attached a picture for your reference. Thank You |
December 10, 2019, 10:47 |
Lucky
Rep Power: 65 |
2) There's a force report/monitor.
1) You should be able to use a pressure inlet and pressure outlet (with targeted mass flow rate settings). You need to specify the stagnation pressure at a pressure inlet (and not the static pressure). Actually, you can't impose a static pressure at any inlet, it's non-physical, unless the flow is choked. The inlet pressure of 5 bar is known how? I.e. is that the mains pressure or running pressure? Let's say you have a barometer at the inlet. If the pressure is 5 bar when the valve is closed and there is no flow, then when the valve is opened, the pressure will drop slightly to less than 5 bar. However, the stagnation pressure still is 5 bar and you can apply that as your BC. But if you've already opened the valve and then you take a peek at the barometer and you see it reading 5 bar with flow, then that's the static pressure obviously. But now you don't know the stagnation pressure. Unfortunately, there's no way to impose an inlet static pressure because it's non-physical unless the flow is supersonic. |
CGNS Boundary conditions using SU2 | denzell | SU2 | 3 | July 9, 2018 05:58 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
