-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   No steady solution for airfoil at high AoA (https://www.cfd-online.com/Forums/fluent/223594-no-steady-solution-airfoil-high-aoa.html)
NonStopEagle January 17, 2020 15:11
Hey guys,
I am trying to simulate a NACA 0015 airfoil at high AoA (about 16 degrees)
I am getting oscillating cl and cd values when I run a steady simulation.
Upon switching to an unsteady simulation, for very small time steps( of the order 1e-5) the cl and cd values become constant, but are incorrect. When I increase the timestep ( to about 1s or 2s) the oscillating behavior of cl and cd plots returns.
How do I get convergence?
NonStopEagle
AidealZohary March 3, 2021 15:52
Hi, I did not use NACA 0015 and at a high AOA. But I do know that the stability of the unsteady simulation is also important. I outlined some steps that I did to get around it. Perhaps can be helpful. Take a look:
Numerical Investigation on the Pressure Drag of Some Low-Speed Airfoils for UAV Application.
Unsteady 3-equation k omega intermittency SST was used. Good comparison with XFOIL and experimental data. Transition features also shown through cf and cp plots.
