please help!! I need to get velocities at points whish are not at nodes. (2D) |
January 26, 2020, 22:20 |
Rai Shigeta
Rep Power: 6 |
I need to write a UDF that will read a point coordinate from a table and provide me with Velocity(u and v) at that point. That point might not be at a node, so fluent would have to interpolate.
Is there a UDF line command to get the Velocity at a specific X,Y location? |
January 27, 2020, 05:49 |
Alexander
Rep Power: 34 |
my vision:
you may use loop over cells and get coordinates of centers of these cells, compare them with data from table, extract velocity and interpolate it yourself
best regards ****************************** press LIKE if this message was helpful |
January 28, 2020, 06:56 |
I am still lost...
#3 | |
Rai Shigeta
Rep Power: 6 |
I was working on that way that you suggested. However, I couldn't find a good way to interpolate it for myself. I'm afraid to ask that Do you know any good way to interpolate it from the data of centers or nodes, kind of using any free-software or some? Or Could I ask your vision again? I'm not majoring this kind of things and I need to graduate soon... Is it easier to do it myself without using UDF or TUI things? |
January 28, 2020, 07:20 |
Value from cell center or interpolated value
Hi Rai
Do you wish to extract value from the cell in which the point lies or do you wish to interpolate the values from the adjacent cells or nodes to your point and report that? For the later, you have to use some interpolation algorithm. If mesh is fine, I would suggest using 0 order interpolation, i.e., the nearest node value or picking up the value from the center of the cell in which the point exists. There are a couple of macros available within Fluent to find the id of the cell in which a given point lies. You may use DPM_Locate_Point(x,&a,0.0,0) where x is the vector containing point coordinates and a is the variable to cell ID. There certainly could be better solutions available depending upon the version of Fluent. Once you have the cell ID, you may loop through all nodes or faces and retrieve interpolated value. Vinerm |
January 28, 2020, 23:26 |
first order interpolation
#5 | |
Rai Shigeta
Rep Power: 6 |
But it seems like that what I need is 1 order interpolation (linear interpolation?). The detail of my circumstances is here: I'm doing 2D air flow analysis in square region(100mm×100mm). I need the value of the points that are located at (x,y)=(1,1),(1,2)...(99,99). Now I've got the values of 0 order interpolation which is like the same values as the closest nodes. But thanks anyway, I really appreciate that you took your time to consider my problem. |
January 29, 2020, 03:27 |
Justification
Hi
Linear interpolation would be very expensive since you have to calculate the distance of each node from the point within the cell and then calculate the value. On the other hand, averaging over nodes would not be that expensive. However, it is difficult to justify to go into all this. 0 order interpolation is quite close to 1st order if mesh is fine enough.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 12, 2020, 06:00 |
Once you get the ID of the cell containing your point, it is as simple as retrieving both the cell value and the gradient of the variable you want to interpolate, then just:
phi_point = phi_cell + SUM(grad_cell(i)*(x_point(i)-x_cell(i)),i=1,ND) Depending from what you want to do, it might make sense to properly distinguish between pure gradients and reconstruction gradients, both of which are available. You might need to use the TUI to tell Fluent to avoid freeding the memory for the gradients. |
March 11, 2020, 05:26 |
Extracting flow data at tabulated points
han
Hi, I was looking for the same, thought it would be a straightforward question, however did not find a working example for Fluent 18. I started UDF programming but ran into the problem of undocumented functions, type conflicts nd so on. As a quick workaround I made a script (any language will do) that makes a Fluent journal file "MakeJou.jou". The scripts reads a file ("points.txt") with points (x, y, z), generates the TUI commands to make the point-surfaces, to export the flow data at the point-surfaces to file "DataAtPoints.txt", and to delete the point-surfaces again, as not to leave traces in Fluent.
Code for generation of journal file MakeJou.jou (this case Mathcad 15) [IMG]C:\tmp\tmp.bmp[/IMG] Example: ---------- File with points (x,y,z, coordinates) "points.txt": 0.55 -0.04 0.0045 0.3 0.05 0.0001 -0.55 0.05 0.0001 Autogenerated Journal file "MakeJou.jou": q /surface point-surface Point-1 0.55 -0.04 0.0045 point-surface Point-2 0.3 0.05 0.0001 point-surface Point-3 -0.55 0.05 0.0001 /file/export ascii DataAtPoints.txt Point-1 Point-2 Point-3 yes xvelocity yvelocity zvelocity velocity pressure temperature density viscosity-lam q no yes 0 q /surface/delete-surface Point-1 /surface/delete-surface Point-2 /surface/delete-surface Point-3 File with output for each data point "DataAtPoints.txt": nodenumber, x-coordinate, y-coordinate, z-coordinate, viscosity-lam, density, temperature, pressure,velocity-magnitude, z-velocity, y-velocity, x-velocity 1, 5.500000000E-01,-4.000000000E-02, 4.499999762E-03, 8.906351952E-06, 8.156205730E-06, 2.969481164E+02, 9.988928086E+00, 1.775980586E+01,-8.117933759E-01, 1.176474198E+00, 1.769677456E+01 2, 3.000000104E-01, 5.000000000E-02, 9.999999404E-05, 8.837132723E-06, 1.846997675E-05, 2.935214512E+02, 2.235924084E+01, 9.385820385E+00, 1.460540274E-04, 0.000000000E+00, 9.385820342E+00 3,-5.500000164E-01, 5.000000149E-02, 9.999999404E-05, 8.840741512E-06, 4.097106808E-05, 2.937000280E+02, 4.962854152E+01, 1.299232211E-01,-8.431707945E-05, 0.000000000E+00, 1.299228378E-01 |
March 11, 2020, 05:33 |
#9 |
han
[snappyHexMesh] .STL: non-closed manifold surface | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 32 | November 25, 2016 03:15 |
[mesh manipulation] Calculate cross product of mesh points and given vector | DE25VT | OpenFOAM Meshing & Mesh Conversion | 5 | January 13, 2016 10:05 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
extreme points problem | Lipo Wang | Main CFD Forum | 2 | August 18, 2004 03:15 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
