please help,open tank problem
Old   August 20, 2008, 06:14
Default please help,open tank problem
raju
hi,i will be really grateful to you.
problem: my tank is open to atmosphere,1/3 filled with water.remaining is air inlet and outlet is in the botttom,which is circulating the water in the tank and maintaining constant level.it is some steady type problem..
i tried lot to solve it by VOF model cosidering two phase flow,,,..but i m not getting seperate path line for air and water......so how i should solve it..
please help me.
Old   January 28, 2020, 01:49
Default Pump Sump Simulation
Michael Jeremy
michaelsinaga is on a distinguished road
hey im simulating a multiphase flow in an open tank with outlet to pump suction pipe and inlet from the side of the tank. about 2/3 of tank is filled with water and the rest is air. its like a steady flow. i have a problem that my flow is not making a lot of sense with the water is jumping to the top of the tank. i set the boundary conditions with velocity inlet in the side, pressure outlet at the pump suction, and pressure outlet at the top with atmospheric pressure. please, anyone, i need your help.
michaelsinaga is offline   Reply With Quote
tank filling problem with compressible air Cle FLUENT 1 March 8, 2012 23:02
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 02:32
Open Tank with propeller Pankaj CFX 5 May 27, 2007 16:40
CFX 5.5.1 stirred tank and LES problem Nishant CFX 2 September 13, 2002 07:11
Tank problem using CFD meda Main CFD Forum 3 July 1, 1999 21:44
