Non-Newtonian turbulence modelling
Dear all,
I've been tasked with setting up a simulation to which the details I describe below: • There are two fluids that come into contact and mix and the goal is to capture this mixing as better as possible • The whole system is pressurized (at around 24 MPa) • On one side there’s hot compressed water (temperature around 350 C) • The other fluid is a biomass slurry close to ambient temperature • The biomass slurry presents strongly shear-thinning, viscoelastic behavior and to have a significant concentration-dependent yield stress • The Reynolds number for most flow rate cases is around 1000, but can vary from 300 up to 5000 • The system’s geometry consists of 2 concentric tubes, with the hot water entering through the smaller tube and the slurry through the bigger one • The tubes are of small dimension (in the order of mm) so I’m unsure about the influence of wall effects on the fluid flow and behavior I do have a k-epsilon model with custom wall and damping functions to deal with the non-Newtonian behavior of a similar fluid, although I'm unsure if the fluids are similar enough for this approach to be applicable for my case. With the absence of any results to validate my simulations, I'm thinking about testing the results from the k-epsilon model I have against a k-omega model (it should at least confirm whether the wall functions are applicable). Can any of the k-omega models implemented in Fluent deal with multiphase flows or should I just use the k-epsilon model I have? Any suggestions would be greatly appreciated (even a different approach that I haven't considered). Kind regards, Dinis |
Thank you in advance, Dinis |
Ewt
You're saying that this is not necessary or that actually I will have cases in the laminar regime? The ultimate goal is geometry optimization and/or flow rate increase of the system I'm simulating so a model that can account for turbulence is necessary. Kind regards, Dinis |
Transition model vs its existence
Thanks a lot, Vinerm!
I do have another question regarding the wall treatment. I've checked this post and from what I understand, the uses a blending functions for the velocity and the k equation but not , correct? If so, the blending function will still use pre-defined values to achieve this smooth transition between layers. This treatment will still be valid for non-Newtonian multiphase flows? In the end, high accuracy is not of utmost necessity, but I need to have confidence that my results are realistic (especially because the fluids and condition to model are not at all typical). With this in mind, and if the wall effects are not that significant for the properties mean values, or the model is sufficient for this purpose, then I will go with that approach. Again, thank you for your help! Kind regards, Dinis |
Blending Functions
Blending functions are used by SST to blend and at the outer boundary layer. This transition is not a fixed value, rather a function of k, as well as mesh resolution and fluid properties. This is applied to both k and but not to velocity. I suppose what you are talking about are enhanced wall treatment. But there as well the blending function is not used for momentum or k. It is used to define eddy viscosity in a manner that makes it compatible with the eddy viscosity in the outer layer
I don't quite understand what you mean regarding the enhanced wall treatment though. Just to clarify, there are no wall functions here and the wall treatment is just the application of the model near the wall, correct (which then is blended with the model to be applied far from the wall)? Yet another question that has popped up when watching the video I linked. I guess checking the value is not really what I should be doing to see if my mesh is adequate for my simulation case but rather the blending function and values? If so, how can I check these in Fluent? |
Not available for selection
Can I plot them in Fluent? |
Use expert options
Those are available under Turbulence category if you tell Fluent not to free up the temporary memory (use the following command)
sol set exp |
