Udf
Hello guys,
I need to write a UDF to get the value calculated within to fluent to be inserted as input parameters My problem is multi species: Lewis = (k/p*Cp)/Di which fluent help calculate the temperature dependent thermodynamic properties -> mixture thermal conductivity,k -> mixture density of species, p -> mixture heat capacity, Cp The lewis number is constant value so no problem My aims is to calculate the diffusion coefficient for each species, Di from these output parameters. |
Di = (k/p*Cp)/Lewis
use Ansys Fluent Customization manual to fined information on UDF you should describe what do you mean under "using as input parameters": where? show your code to discuss your problems |
1 Attachment(s)
i attached a picture, when i write the UDF, the circle thermodynamics properties will be my the input parameters(during the simulation, perhaps like a loop), my friend told me the stored data will be inside the folder and can be extracted, but i not sure how to do it. Sorry for my bad English
to find information on writing to file in Fluent:
1. read manual I've mentioned, search for Input/Output Macros 2. search through forum "write to file" 3. google show your code if you have any problems |
Standard Macros
There are standard macros to do that. Since you need these properties to define diffusion coefficient, they have to correspond to same cell. Look at the example 2 given in UDF manual
https://www.afs.enea.it/project/nept...udf/node46.htm Here PROP_ktc is thermal conductivity. You cannot use PROP_ macros to modify the properties, but you can use these to calculation and return any property with DEFINE_PROPERTY. Similarly, you have PROP_rho, PROP_Cp, PROP_mu, etc. All these are given in material.h located in Fluent's source directory at installation location. |
thank you, the material.h is useful indeed
