February 10, 2020, 10:11 |
Assigned Values to UDM via Profile in Fluent
Raphael
Rep Power: 13 |
Is it possible to assign values to a user-defined-memory using a defined "profile" in Fluent? Or is it only possible via UDF?
TIA |
February 10, 2020, 10:21 |
I don't think so, and a define_profile would still be in a UDF (it was last time I checked).
If you explain what you want to do, maybe we can help more (but the Fluent forum would be better suited) |
February 10, 2020, 10:40 |
#3 | |
Raphael
Rep Power: 13 |
I think you are interpreting my question backwards. I don't want to define a profile with a UDF; I was asking if the only way to define a UDM is through a UDF. I already have a profile text file, which I can import and use anywhere, but i want to plot it, and the only way I can think to plot the contour plot is by using the profile as a UDM, since Fluent lets you plot the UDM. |
February 10, 2020, 10:48 |
Ok, I misinterpeted profile with a define_profile.
I don't know/remember if this (UDM) is your only chance to plot profiles (but I'm pretty sure it isn't). UDF is the only way I know to fill a udm, but maybe you should check your version manual. |
February 10, 2020, 10:53 |
#5 | |
Raphael
Rep Power: 13 |
I checked the manual, and it doesnt look good... |
February 10, 2020, 13:13 |
Lucky
Rep Power: 65 |
Check out this thread for some maybe helpful hints.
It's a unconventional question because once you're in udf land, you can just read the profile file directly using programming and not relying on a scheme command. Also. In the future. Please don't double/triple/quadruple/quintuple post because now you get conflicting solutions on different threads when they all could've been in one place. |
February 10, 2020, 18:48 |
Raphael
Rep Power: 13 |
I think you misunderstood my question... I want a solution that doesnt involve UDFs, since the whole point of using a profile is to avoid using UDFs.
February 11, 2020, 07:59 |
#8 | |
https://www.afs.enea.it/project/nept...g/node1225.htm |
February 11, 2020, 10:16 |
#9 |
Lucky
Rep Power: 65 |
When I read a title of how to assign a PROFILE to a UDM, I assumed it was about assigning a profile to a UDM. Sorry I didn't sift through your other dozen threads to discover that this entire time it was never about getting a UDM, you were just trying to make a plot of a PROFILE. Anyway it appears your query was answered (in another thread). My rant is unironically necessary to bring closure to this query because someone in a few years will google this same post and rage about why it was never answered and how unhelpful this community is.
February 11, 2020, 10:17 |
#10 | |
Raphael
Rep Power: 13 |
This thread focused specifically on that, whereas the other thread focused on the main problem I wanted to solve. |
February 11, 2020, 10:19 |
#11 | |
Raphael
Rep Power: 13 |
2 dimension temperature profile as boundary condition in FLUENT | kzf | FLUENT | 9 | June 1, 2021 21:02 |
Fluent give me opposite stream function contour values | kbaker | FLUENT | 7 | August 14, 2017 12:47 |
Reference Values in Fluent | Mansoor_shad | FLUENT | 0 | July 12, 2017 00:44 |
Slow overwriting of parameter values when Fluent is opened | zubs | FLUENT | 0 | April 10, 2015 05:18 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
