need help convergence problem
Like Tree2Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   February 13, 2020, 00:57
Default need help convergence problem
mahmoud ali saad is on a distinguished road
hi all , i need help with my model . the problem is with residuals in continuity dosent reach 10-3 and by monitoring the results doesn't reach constant value .
solver setting :
simplec , second order scheme for pressure and quick scheme for all other convection parameters.
the model and mesh and results in photos
mahmoud ali saad is offline   Reply With Quote
Old   February 13, 2020, 04:24
Default Use Coupled
vinerm's Avatar
Vinerm
vinerm is on a distinguished road
Mahmoud, for such a system, prefer using Coupled with pseudo-transient. Furthermore, no need to use QUICK. Difference between QUICK and second-order would be too small.
mahmoud ali saad likes this.
Regards,
Vinerm
PMs only for private content
vinerm is online now   Reply With Quote
Old   February 14, 2020, 05:45
THANKS vinerm , its works but the coupled solver induced back flow(rise the error) even with down steram flow 2.5times the model length .so what is your recommendations for that problem.
great thanks for your help
Old   February 14, 2020, 06:05
Default Flow reversal
vinerm's Avatar
Vinerm
In some cases, flow reversal is realistic, such as, for cases with obstructions very close to the outlet. Otherwise, you should observe that as the iterations proceed, the number of faces having flow reversal reduces. In case it is not reducing then the obstruction is too close to the outlet and you should extend the domain; recommended is 6 times the hydraulic diameter away from any obstruction. If reversal exists only on a couple of faces, you can ignore that. Extension would not be justified.
Regards,
Vinerm
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 03:14
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 07:03
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 10:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 04:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
