February 12, 2020, 23:57 |
need help convergence problem
Rep Power: 6 |
hi all , i need help with my model . the problem is with residuals in continuity dosent reach 10-3 and by monitoring the results doesn't reach constant value .
solver setting : simplec , second order scheme for pressure and quick scheme for all other convection parameters. the model and mesh and results in photos |
February 13, 2020, 03:24 |
Use Coupled
Mahmoud, for such a system, prefer using Coupled with pseudo-transient. Furthermore, no need to use QUICK. Difference between QUICK and second-order would be too small.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 14, 2020, 04:45 |
#3 | |
Rep Power: 6 |
great thanks for your help |
February 14, 2020, 05:05 |
Flow reversal
In some cases, flow reversal is realistic, such as, for cases with obstructions very close to the outlet. Otherwise, you should observe that as the iterations proceed, the number of faces having flow reversal reduces. In case it is not reducing then the obstruction is too close to the outlet and you should extend the domain; recommended is 6 times the hydraulic diameter away from any obstruction. If reversal exists only on a couple of faces, you can ignore that. Extension would not be justified.
Convergence problem in Fluent for quenching process | kaeran | FLUENT | 4 | December 1, 2014 02:14 |
Rotate frame reference convergence problem! | wjy-c | CFX | 2 | September 26, 2014 06:03 |
Centrifugal pump OpenFOAM, convergence problem, ANSA model | RDD | OpenFOAM Running, Solving & CFD | 0 | July 5, 2014 09:12 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
