February 8, 2020, 07:56 |
Magnetic-Particle(DPM,MHD)
hooshyar
I want to simulate a particle by DPM Method after that I want to apply a MHD for control volume that the particle will be effected by a magnetic field.The particle will stick to the wall and هt will be a magnet for attaching other particles. So how can I simulate that Particle after attaching by magnetic-wall, The particle itself becomes a magnet.
Any help would be appreciated regards |
February 9, 2020, 16:33 |
Magnetic Particle
There are two scenarios mentioned in your post; one is that the particle attaches to the magnetic wall and second one is that the particle becomes a magnet and then attaches other particles. Do you want both of these scenarios to be applied or only the former one?
The former one is easier than the latter one but is not easy in itself. Fluent offers a trap bc and you can apply this via a UDF based on certain criteria, such as, if particle is within a certain proximity to the wall, it should move towards the wall and then get trapped. As far as the motion of the particle is concerned, you can apply extra force on the particle as a body force. This also needs to be done via UDF. If you can elaborate more on the situation you want to implement, better suggestions could be expected.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 14, 2020, 04:51 |
hooshyar
tanks a million,
As you said, "one is that the particle attaches to the magnetic wall and second one is that the particle becomes a magnet and then attaches other particles" so I want to simulate both of them simultaneous. I mean, the particle attaches to the magnetic wall and after the attached particle becomes a magnet and then attaches other particles to that. as a mather of fact, I simulated a channel that the particle attached to the wall by DPM and MHD but I don't know that does the particles have become a magnet for attaching the other particles??? and also do I should write a UDF for solve this problem??? |
February 14, 2020, 06:17 |
DPM with MHD
Particles will not become magnetic on their own. Furthermore, once particles are trapped by the wall, they disappear. Physically, it may not matter whether the wall attracts another particle or a particle attached to the wall until and unless a lot of particles get attached at same location and the magnetic strength increases at that particular location.
dpm, fluent, mhd |
Display Modes | |
Multi-region solver for electric and magnetic fields + charged particles | Dzhordzhs | OpenFOAM Running, Solving & CFD | 22 | May 2, 2022 22:59 |
External Magnetic Field Data Format for FLUENT MHD Module | eduardvinter | FLUENT | 0 | January 24, 2019 02:54 |
(MHD simulation)Can magnetic force be the driving force of ferrofluid? | yaoxy | FLUENT | 0 | June 4, 2013 03:14 |
vof simulation...magnetic fluid pressure fields. | Souviktor | FLUENT | 0 | May 22, 2010 03:19 |
particles in a localized magnetic field | Arturo Ortiz | FLUENT | 1 | March 10, 2010 11:26 |
