Pressure inlet boundary condition
I want to translate the pressure-inlet boundary condition that I am using on Fluent to another CFD solver. I have the following options The Dirichlet boundary condition. Neumann boundary condition. Which would be most suitable in this case? Any help will be appreciated. Thanks |
Applying a pressure value on a boundary is a Dirichlet type in pressure. But make sure this is a Dirichlet for pressure (and not velocity).
Dirichlet means you fix the value. Neumann means you fix the gradient. |
Pressure Condition
As mentioned, it is Dirichlet. However, there is no conservation equation for pressure, hence, pressure value is not directly applied at the boundary. It is used to determine a velocity and that is applied. Pressure value is used only as a reference to adjust the pressure-field in the rest of the domain.
