inlet, outlet and body of a curved pipe not recognizable in Setup |
June 17, 2020, 21:44 |
I am trying to simulate water flow through a curved pipe with a conical sweep. I built the geometry using Rhino6, it generates drawing with .igs and many other extensions that Ansys Fluent can read. The final geometry was a poly-surface. I can import it and generate a mesh and an inflation, but when I reach the Setup stage, the Named Selection edges of the inlet and outlet are not visible in Boundary Conditions. I also struggled to generate the Boundary of the body since it only recognizes it when I use Smart Select for the mesh and the inflation. I am hoping to get a velocity profile of the water flow but since the inlets are not recognizable, the Contours can not be generated. please let me know if you need any files or information to help with this enquiry. |
June 17, 2020, 22:11 |
Alexander
Rep Power: 34 |
try following
make mesh in workbench mesher, define name selections
best regards ****************************** press LIKE if this message was helpful |
June 18, 2020, 10:50 |
thank you for replying so swiftly.
I already created the inlet, outlet and body Named selections. They appear in below the mesh in the mesher but not in the Setup to be selected as the Cell Zone and Boundary. |
flowrate, mesh, outlet, set up |
Display Modes | |
velocity BC for inlet and outlet | SimuJo | OpenFOAM Pre-Processing | 1 | June 23, 2020 08:59 |
Water fountain from a vertical pipe inside another water body with lesser density | mahsankhan | OpenFOAM Running, Solving & CFD | 5 | April 4, 2020 07:26 |
[DesignModeler] How to create smaller pipe inside bigger pipe? | Munggang | ANSYS Meshing & Geometry | 2 | March 7, 2012 14:01 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
