March 10, 2020, 07:10 |
Hypersonic Simulation Boundary Conditions
Cpt. Convergence
Rep Power: 8 |
Dear all,
I have to simulate a hypersonic case. I have already programmed the user-defined real gas model in order to take into account dissociation and ionization effects. However with this model I cannot use pressure far-field because it is not an ideal gas. Therefore I should use a velocity inlet and a pressure outlet. I have been doing 2D attempts (see attached images of the mesh and domain) with an inviscid ideal-gas to see how these BC work together in hypersonic regime (i.e. inlet velocity 1500 m/s, Mach 4.4). I am using inflation only to accommodate the flow towards the wedge. Regarding the solver: -Density-based -Explicit formulation to ensure convergence -Flux type AUSM -Gradient: Gree-Gauss Cell Based -Flow: 2nd order upwind -Courant number: 0.25 -High Order Term Relaxation (Flow Variables only): 0.25 My simulations diverge completely. My guess is that the V. Inlet and the P. Outlet do not work properly when they are directly connected (see the upper right corner). Should I switch to a flat top with symmetry or a wall with slip conditions? I would love to hear some suggestions. |
March 10, 2020, 07:49 |
Velocity Inlet
With a compressible system, Velocity Inlet is not supposed to be used. Either use mass flow inlet or pressure inlet.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
March 10, 2020, 10:37 |
Cpt. Convergence
Rep Power: 8 |
Thank you so much! It worked!
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
