how to find a mean temperature in helical tube in fluent.
Old   March 14, 2020, 04:31
Default how to find a mean temperature in helical tube in fluent.
mox123 is on a distinguished road
I am trying with method of making planes and finding the mean temperature on each plane. but the plane in fluent is not coming perpendicular to the helical tube radial/tangential axis. How can I proceed?
mox123 is offline   Reply With Quote
Old   March 15, 2020, 16:46
Default Planes
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Planes in Fluent will be created as per the user inputs. To create planes normal to helical axis you need to provide local normal at each point. A simpler solution would be to get these normal vectors and positions from the CAD tool. A more sophisticated solution would be to use local orthonormal basis and then create normals. This has to be done either using Scheme or C based UDF.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 16, 2020, 10:49
Can u tell a way to find a normal vector and position in solidworks. because after using helix with sweep tool it is not showing coordinate on each point.
Old   March 16, 2020, 11:23
Default Solidworks
vinerm's Avatar
Vinerm
I am afraid I have no idea about SW. May be someone else in the forum might help. However, if you use DM or SCDM, you can create planes within that CAD tool or, as suggested earlier, use equation of helix.
Regards,
Vinerm
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Evaporation condensation below saturation temperature in FLUENT user321 Fluent Multiphase 1 January 29, 2020 06:41
Can't Get Temperature distribution in Solids in Fluent (Pipe cooling) Bobby Charlton FLUENT 0 December 31, 2019 20:07
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 07:08
liquid temperature at tube outlet? phsieh2005 Main CFD Forum 0 October 11, 2010 21:33
