View with cut plane
Like Tree1Likes
  • 1 Post By -mAx-
Old   May 25, 2010, 15:05
Default View with cut plane
Patrick Young
Mudblood is on a distinguished road
Hi
I am wondering how to view my 3D contours in a cut plane. I modeled a 3D cylinder that is symmetrical. I want to view down the centre in a cut plane. I made the plane (0,0,0), (0,1,0), (1,1,0), and click display for it, but obviously that only gives me a rectangular appearing sliver of the cylinder. I want to see half of the cylinder, on that plane. How can this be done?
Thanks
Mudblood is offline   Reply With Quote
Old   May 26, 2010, 01:28
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
*display/sweep surface
*or surface/isosurface (surface of constant: choose the right coordinate)
hicabiye likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 26, 2010, 12:56
Patrick Young
After playing around with those features, I'm not sure that they can do what I'm aiming for.
I'm trying to create a diagram like the one seen here, in the top right corner, image titled "CFD MODEL":
http://www.tideflex.com/beta/documen...ctProfile1.pdf
Thanks
Old   May 27, 2010, 01:24
-mAx-'s Avatar
Maxime Perelli
follow (and persevere) what I mentionned earlier.
What you see in your document, is many contour displays overlayed.
It can be done with display/scene (option overlay enabled)
Old   January 16, 2020, 12:46
Zohaib Altaf
zohaibaltaf.6 is on a distinguished road
Dear I have similar problem, did you find any way to plot contours on a sector of a plane instead of the whole plane. I need to find distortion coefficient and thus need to divide a plane to a 60 deg sector. Can you help me with that?
zohaibaltaf.6 is offline   Reply With Quote
Old   April 4, 2020, 10:17
Smile
Richardpluff
CRI_CFD is on a distinguished road
I am also interested in this issue. Did you manage to divide your plane in 60 degrees sectors?
Thanks
CRI_CFD
CRI_CFD is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Plotting Residuals ata OpenFOAM 12 July 8, 2011 02:50
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
[OpenFOAM] View the pressure drop contour in a cut plane 2D in a right position zhoubinwx ParaView 3 February 13, 2008 04:46
cut plane? qiaomu FLUENT 1 May 12, 2003 17:24
