[Sponsors] | |||||
Stefan Schmid
Rep Power: 0 ![]() |
I am trying to model a regeneratively cooled rocket nozzle. I have some empirical data for the modeled nozzle which states that heat flux through the nozzle wall should be between 2500 to max 20000 W/m^2 at the throat. However so far I always get heat fluxes between 16000 to 45000 W/m^2 which is way too high. Due to this, the wall temperature also gets too high (up to over 1000K while it should be around 650K max). Pressure and velocity values match to empirical data, only the temperature and heat flux is off afaik. Is it maybe a problem with the mesh? I'm using the k-omega SST model. Any feedback is highly appriciated. Regards Stefan |
It depends on material properties, Re number, and the boundary condition you have on the wall. Look at the material properties that define Pr and Re. And then check the boundary condition you have applied on the wall.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
| Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
| Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
| Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 01:27 |
| Monitor Heat Flux in CFD-Pre | cltormar | CFX | 5 | November 20, 2014 12:45 |
