[Sponsors] | |||||
Possibilities with DEFINE_UDS_UNSTEADY in Fluent |
Markus Pieber
Rep Power: 12 ![]() |
Dear forum members,
when having a look at Fluent's UDF DEFINE_UDS_UNSTEADY, I noticed that the description and example given in the documentation only uses a first-order accurate time discretization scheme and constant density. Is it possible to use also
Thanks for your help! Best regards, Markus |
The example given is exactly that, an example. You can certainly use second order scheme. As far as density is concerned, it is to be used from the setup. If the density is set as constant in the case setup, there is no point in using a variable density within this function.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 09:08 |
| How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 03:48 |
| Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
| heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
| problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 03:00 |
