Inquiry about inner shaft rotation direction
Old   March 18, 2020, 20:23
Default Inquiry about inner shaft rotation direction
Mohamed Khaled is on a distinguished road
Howdy;
I am simulating 2-phase flow "liquid and soli" in a 90 degree annuls between two horizontal pipe along z-axis. The inner pipe is rotating clockwise around z-axis while outer pipe is stationary
I set motion type to Moving reference frame, then i specify rotation axis. origin 0 to all x,y,z direction, then set x,y=0 and z=1 and i specify RPM=-50 (for clockwise direction)
I tried in two separate run RPM=50 & -50 to be sure that i did it correctly. But When i checked the velocity vector it did not show any clearly direction for both runs (attached)
Even Using RPM=-50, it gives me negative tangential velocity value in the results (which confused me more).
Kindly i am asking if anyone can advise should i put RPM=50 or -50? and why tangential velocity appears negative with -50 RPM
Appreciate your responses
Mohamed Khaled is offline   Reply With Quote
Old   March 19, 2020, 05:01
Default Model
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
First of all, you do not need MRF. All you need is a moving wall. Give a rotation to the wall of the inner pipe. As far as negative and positive are concerned, it is governed by Right Hand Rule, i.e., if rotation about z-axis takes a point from x to y, then it is positive otherwise negative. This implies CCW rotation is positive and CW is negative when positive z-axis is pointing out of the screen. With CW rotation, i.e., -50 rpm, you are supposed to get negative circumferential velocity, so there should not be a confusion about it.
Secondly, you have to ensure that (0, 0, 0) is indeed the center of rotation. Since the pipes not concentric, only one of these would have center at origin.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 19, 2020, 08:57
Default Inquiry about rotation axis origin with eccentric pipe
Sir;
Thanks a lot for your reply and your comprehensive illustration.
Another question if you do not mind regrading pipe center rotation just to confirm with you that i set my boundary conditions probably.
My study case is a rotating inner pipe eccentric from the stationary outer pipe by 0.75 inch
So i put my rotation axis origin (0,0,0) and rotation axis direction (0,0,1) with -50 RPM (for Clockwise rotation).
Is that correct or i should apply eccentricity to the axis origin on y-direction?
From your point of view, why when i plot velocity vectors with 50 & -50 rpm in previous post it did not show clear direction of velocity?
Thanks Again and appreciate your response
Thanks;
MS
Old   March 19, 2020, 09:06
Default Center of Rotation
vinerm's Avatar
Vinerm
Since you want only the inner pipe to rotate, you have to find out, from your CAD model, where does the center of the inner pipe lie. Is it at the origin or is it, say, moved downward? If it is moved, then change the rotation axis origin to (0, -0.75, 0), provided y is the vertical coordinate and unit is set to inch. Else, just provide appropriate numbers.
The difference in -50 and 50 will be clearly visible once the case is setup properly and the solution converged.
Regards,
Vinerm
Old   March 19, 2020, 09:22
Default Model
Thanks a lot sir.
My inner pipe is eccentric downward from center by 0.75 inch. so i will make my center axis of rotation (0,-0.75,0) and rotation axis direction (0,0,1) with -50 RPM (clockwise direction) for my annuls length 40 ft (total length between two pipes)
I will run the model again and check
Thanks;
MS
UDF for 1DOF Rotation ram_call Fluent UDF and Scheme Programming 5 December 29, 2017 14:55
FanPressure BC direction reversal HouchinM OpenFOAM Running, Solving & CFD 1 December 11, 2017 09:42
Direction of rotation Gab CFX 6 November 16, 2017 17:19
Changing inflow velocity direction deteriorates lift and drag ziggo FLUENT 3 July 24, 2013 09:39
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
