[Sponsors] | |||||
Dominick Bastien
Rep Power: 7 ![]() |
Hello, im looking for a major help on ansys fluent. Im trying to simulate a water flow (droplet) that come from the top of a vertical tube (2D). I also have an air flow that come from the bottom of the tube. I need mass transfer (evaporation) in my model. My water inlet need to be my air outlet but It seem impossible on fluent. The water has a temperature of 60 degree celcius and the air 22 degree celcius. I have been trying from my own and looking on google for any tips but nobody seems to have tried these type of model before. Help me please.
What are the diameters for the duct and water droplets? And what volume fraction is water supposed to occupy?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Dominick Bastien
35% is a rather high value for the volume fraction of water. Water will not retain the morphology and become a slug or jet. Are you sure it is volume fraction and not mass fraction?
Dominick Bastien
Ya my bad, I was meaning mass fraction. In detail I need to simulate the flow in a fill of a cooling tower. Im starting with a simple vertical tube. The water flow (droplet) is coming from a sprinkler.
In that case, it is rather run-of-the-mill simulation. You need to use DPM with droplets. Search online with keywords DPM, Droplet, Evaporation, Wet scrubber.
Dominick Bastien
Good, but do you have any tips for my air inlet? My air inlet is my water outlet too and my water inlet is my air outlet too? An inlet-outlet dont seem to work on fluent.
If water volume fraction is less than 10-12%, then water is not to be treated as continuous fluid, rather as dispersed fluid tracked using Lagrangian Reference Frame. With that, bottom will be inlet and top will be outlet, both for air. Droplets will be injected from top using surface injection and escape through the bottom. These will be setup under DPM tab for both inlet and outlet once DPM is enabled and injection is setup.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| problem with two phase flow (air injected in water) | miles_davis | OpenFOAM | 15 | March 31, 2021 10:36 |
| Water Sphere reacting to flow of air modelling | Jacee | FLUENT | 0 | May 25, 2018 10:29 |
| mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
| air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
| 3D-Simulation of Water Flow From Nozzle into Air | Navin Sampath | FLOW-3D | 2 | February 26, 2009 11:46 |
